Giuseppe Larosa Mon, 02/02/2009 - 05:34
  • Hall of Fame,
    Founding Member
Hello Navinder,
you can use
sh proc cpu sorted 1min
to see what processes use more cpu
now I give a look at your sh tech
Hope to help
Giuseppe
Giuseppe Larosa Mon, 02/02/2009 - 05:45
  • Hall of Fame,
    Founding Member
Hello Navinder,
this route
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
causes the router to perform a lot of ARP activity it would be better to provide the ip address of the default gateway so that a single ARP request is enough.
there is a high memory usage from ARP process
10 0 103975180 0 103982160 126519 126518 ARP Input
I would as a start use a default static route pointing to ip addres of default gateway (there is only one possible ip address the net is a /30 so no possible errors here).
Then also the traffic volume has its importance your WAN interface is a FE but the device cannot handle 100 Mbps of traffic to/from the internet
Hope to help
Giuseppe
