Fixing Prompt Recording Software Settings to Cisco Supported Format
Feb 2nd, 2009
<br /><br />Can somebody suggest a software to record & save the prompt directly in Cisco format without having to set the format manually to Cisco supported format manually while saving.
<br /><br />
<br /><br />or
<br /><br />
<br /><br />Is there any way I can fix the format of sound recorder using some registry keys for sound recorder or any other software to pick up automatically Cisco supported format while saving.
Jonathan Schulenberg Mon, 02/02/2009 - 05:22
Two easy ways:
1) Use the Unity Media Master control on either PCA or Unity Administration. Record a prompt and then "Copy to file..." The file will be a G.711u WAV file (assuming Unity is set to G.711u).
2) Write a CCX script that makes a recording and uploads it to the prompt repository. There may be one already built in the "script repository":
