Syed Iftekhar Ahmed Mon, 02/02/2009 - 11:51
  • Blue, 1500 points or more
If VIP is working then Hits should be logged.
Does it shows the same on CLI?
Show statistics dns answer-group {list | }
Syed Iftekhar Ahmed
cisco_lite Tue, 02/03/2009 - 06:56
Two things.
1) I believe once the client D-proxy get a successful response from GSS, it is cached. Hence, subsequent queries are not sent to GSS and hence hit count stays unaffected. Would you know how to disable DNS caching to enforce new name query upon every request.
2) Also, during the hit count update, CLI shows the count whereas GUI takes time. On the page, the note says 'Delay may be upto 300 seconds'. Is that the reason for delay in update. How can the refresh interval be set.
Syed Iftekhar Ahmed Tue, 02/03/2009 - 11:37
1) Lower down the TTL value. TTL value of 0 can make Dproxies to not cache the dns entry. I don't recommend value zero as I have experienced that some DNS distributions do not honor value zero as TTL.So keep it low but no zero.
2)GUI needs to poll the system hence the delay.
Syed Iftekhar Ahmed
