Cisco 1811 site-to-site Troubleshoot
Feb 2nd, 2009
  • Bronze, 100 points or more
Hy,
I have this 1811 model, with two physical interface FA0 and FA1, both connected to ISP. From these two BGP is running and we re using our own IP network.
There are three VPNs site to site with three equipments:
- Juniper
- PIX
- Cisco router
All these three are connecting here to one of my own BGP network. In order to assing connectivity I defined Vlan interface
interface Vlan100
ip address 86.107.A.* 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
All these three VPN access the same resource, an internal server;
So for all three there are three access lists, like this:
access-list 100 permit ip Internal_CLASS VPN1_Remote
access-list 100 permit ip Internal_CLASS VPN2_Remote
access-list 100 permit ip Internal_CLASS VPN3_Remote
All three were on one crypto map:
crypto map NAME 10 ipsec-isakmp
crypto map NAME 20 ipsec-isakmp
crypto map NAME 30 ipsec-isakmp
applied on Fa1. Since Friday it stopped working;
So without any idead I moved VPN 1 crypto map on Fa0 which was free, and it's working fine.
But I am to assign another crypto map on Fa1: the tunnel goes up, but I have only Decapsulated Packets, and no Encapsulation Packets !!
What can I do in this case? Don't understand what went wrong !
Thanks in advance,
Florin.
celiocarreto Mon, 02/02/2009 - 10:45
use a loopback for terminating IPSec.
I applied the crypto map on loopback0 and both physical interfaces and use
crypto map MYMAP local-address loopback0
It works even one interface is down.
Regards, Celio
Florin Barhala Tue, 02/03/2009 - 03:22
Last evening the ISP on FastEthernet1, where all the crypto maps were originally applied admit that he had serious problems since Friday 'till yesterday afternoon!!
Now I have all three VPN kept into one crypto map on FastEthernet0:
crypto map Fa0_map local-address Vlan100
crypto map Fa0_map 20 ipsec-isakmp
crypto map Fa0_map 30 ipsec-isakmp
crypto map Fa0_map 40 ipsec-isakmp
If I am to create an identical crypto map: Fa1_map and apply it on Fa1 which of the two interfaces will be used for VPN ?
