Giuseppe Larosa Mon, 02/02/2009 - 07:20
  • Hall of Fame,
    Founding Member
ello Wang,
the config files that you have tried to attach are not complete.
However, notice that a vpnv4 router can have mutiple RT attached to it.
So you need to verify if the route you see on R5 have multiple RTs
in that case you can have the answer.
to have an exact match that says if one of the RTs is xx:yy deny the route you should use extended extcommunity list
Hope to help
Giuseppe
shivlu jain Mon, 02/02/2009 - 08:47
  • Silver, 250 points or more
Giuseppe
Does cisco support more than 30 rt values attached in bgp update route?
regards
shivlu jain
Giuseppe Larosa Mon, 02/02/2009 - 10:19
  • Hall of Fame,
    Founding Member
Hello Shivlu,
according to RFC
http://www.ietf.org/rfc/rfc2858.txt
there is a byte wide field for the number of SNPAs (note I don't see any reference to route target here it is very general)
and a byte wide field to say how many bytes form a SNPA.
So it looks like possible to associate 30 RTs to a vpnv4 prefix but be aware that memory usage can grow very quicky.
see also
http://www.ietf.org/IESG/Implementations/mp-bgp-implementation-report.txt
this is not very new but provides info about different vendors implementations of MP-BGP.
But this is theory and implementation may put some limit to the number of RTs
Hope to help
Giuseppe
Harold Ritter Tue, 02/03/2009 - 14:18
  • Cisco Employee,
Giuseppe,
IOS would allow you to have up to 128 RT extended communities in one BGP update message. Bear in mind that the maximum BGP message size being 4096, it would not leave you much space for anything other than the extended communities.
Harold Ritter Tue, 02/03/2009 - 14:23
  • Cisco Employee,
Giuseppe,
Sorry, 128 is actually the old limitation. I just checked and the latest 12.0S code would allow in excess of 500 RT extended communities. I don't know if anyone would like to go that far though.
