incoming FAX on SIP trunk - CME
Answered Question
Feb 2nd, 2009
hi guys,
I am trying to setup fax on my CME gateway, I have a SIP trunk to my PSTN provider and incoming and outgoing calls are SIP. My fax machine is connected to the network via a Cisco ATA and when I make a call the fax rings and gives me fax tone after few rings but there is no fax. Could you please tell me the SIP dial-peer config for fax and debug commands to troubleshoot.
many thanks,
K
Correct Answer by Nicholas Matthews about 8 years 2 months ago
Hi Kiran,
Check your SIP network for packet loss - 'show call active voice brief | i lost'.
Try this command:
voice service voip
fax passthrough codec g711ulaw fallback none
You can try T38, to see if your provider supports it (some do):
voice service voip
fax protocol t38 fallback none
There is more to faxing than just G.711 - it increases the jitter buffers and turns of echo cancellation. It is important for all DSPs involved to do this, so setting it to G.711 isn't enough.
hth,
nick
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 02/02/2009 - 04:22
  • Hall of Fame,
    Founding Member
Have you disabled fax relay ? "fax protocol none". Also make sure you're using G.711 with ITSP, else fax cannot work.
kiranoddiraju Mon, 02/02/2009 - 04:28
yes I am using G.711 and do I need to disable fax protocol?
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
paolo bevilacqua Mon, 02/02/2009 - 05:05
  • Hall of Fame,
    Founding Member
Yes because it's unlikely that ITSP supports one.
Note in practice g711a is never used over voip even outside N.A. and you can safely omit it, so having a single coded under DP instead of codec class.
Correct Answer
Nicholas Matthews Mon, 02/02/2009 - 17:42
  • Red, 2250 points or more
Hi Kiran,
Try this command:
voice service voip
voice service voip
hth,
nick
kiranoddiraju Tue, 02/03/2009 - 03:58
Thanks Nick, I have tried with t38 and passthrough g711ulaw but it doesnt work. The fax rings on the otherside and I can see on my fax it is trying to connect at different speed (9600,7200,4800 & 2400) and fails.
I have no DSP's on the gateway.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
My Dial-peer config:
dial-peer voice 9 voip
description <<< Outbound to Telco >>>
translation-profile outgoing outgoing_digits
destination-pattern 9.T
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target ipv4:xx.xx.xxx.x
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
description <<>>
translation-profile incoming incoming_digits
voice-class codec 1
incoming called-number .
dtmf-relay sip-notify
no vad
Nicholas Matthews Tue, 02/03/2009 - 05:45
CUBE will play no part in the faxing other than signaling.
Please make sure that this is configured on your endpoints.
We had some problems with faxing on CUBE in 20.T1 I believe. If you're not on 22T you may want to try it.
-nick
Nicholas Matthews Tue, 02/03/2009 - 06:49
H323-SIP is CUBE. You shouldn't because it's how your calls are working :)
If you're using CUBE but not paying the licensing for it ... you may want to look into it :)
If the fax machine is hooked up to an FXS port, that that's the gateway you're interested in. If it's an IP fax server, you won't be able to change most of the fax settings on a gateway.
-nick
kiranoddiraju Tue, 02/03/2009 - 07:01
I have a SIP interconnection with my ITSP, so I assume it is SIP-SIP. I cant use FXS as I dont have DSP's on the gw.
kiranoddiraju Tue, 02/10/2009 - 05:46
Nick, its working now after I forced it to T38 and set fax rate to 9600 and did the same on the Telecom side.
Many thanks for your guidance.
