voice translation rule characters
paolo bevilacqua Mon, 02/02/2009 - 05:32
  • Hall of Fame,
    Founding Member
There is no way. Although sometime non-standard formatting like ()- is seen in numbers, Cisco doesn't support that.
Nicholas Matthews Mon, 02/02/2009 - 17:51
  • Red, 2250 points or more
If you're using SIP this is possible. You can do some SIP header modification that will translate almost anything in the SIP header. So, if you change your GW configuration over to SIP, you will be able to do outbound header translation (not inbound).
Thought this might help.
-nick
