T1 PRI
Answered Question
Feb 2nd, 2009
I check the cisco 1800 product and it support T1 PRI
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_setup.html#wp34472
Any idea if I buy two 1800 boxes and phase out the AS530. pls advice
rdgs
Correct Answer by paolo bevilacqua about 8 years 3 months ago
T1 config is the same. For most uses, the voice features will be the same.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 02/02/2009 - 05:42
  • Hall of Fame,
    Founding Member
It can be done, for data calls only.
Or keep a single box (28xx), less administrative work.
paolo bevilacqua Mon, 02/02/2009 - 06:20
  • Hall of Fame,
    Founding Member
For voice calls, the 1861 and the 28xx do support that with VWICx-xx-xxx.
For modem calls, you need a 2811 as minimum, with HWIC-1CE1T1-PRI and PVDM2-xxDM.
anitachoi3 Tue, 02/03/2009 - 05:11
one more question, is the config of 2861's T1 pri the same as 5300's T1 pri config? which voice feature(s) 2861 does not support?
rdgs
Correct Answer
paolo bevilacqua Tue, 02/03/2009 - 05:16
  • Hall of Fame,
    Founding Member
