CME Phone Issue
Feb 2nd, 2009
I am trying to add a new 7921 onto the CME box. The phone is authenticated on the wireless, the only problem is that I can't seem to get the phone to register with CME.
When I add the ephone's MAC address, I will see the below logs from TFTP. I have confirmed that correct MAC address of the phone. It is ephone 6.
Jan 29 16:52:07 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:52:07 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:11 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:15 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:19 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:23 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:27 CST: TFTP: Looking for WLAN0021A0244B35.xml
Jan 29 16:52:07 CST: TFTP: Looking for WLAN0021.A024.4B35.xml
Jan 29 16:53:53 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:53:57 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:01 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:05 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:09 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Jan 29 16:54:13 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
<br /><br /><br /><br />
kelvin.blair Mon, 02/02/2009 - 07:21
  • Silver, 250 points or more
Something simple to try.. Have you tried a factory reset of the phone? If not, here are the steps..
Arrow Down to Settings
Select Phone Settings or press 1
Press **2
Quickly press Yes to confirm (left soft key)
joshehaos Mon, 02/02/2009 - 07:49
Still getting the same message after reset.
Feb 2 09:38:34 CST: TFTP: Server request for port 1024, socket_id 0x489A3B7C fo
r process 250
Feb 2 09:38:34 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:34 CST: TFTP: Looking for CTLSEP0021A0244B35.tlv
Feb 2 09:38:34 CST: TFTP: Sending error 1 No such file
Feb 2 09:38:35 CST: TFTP: Server request for port 1024, socket_id 0x496F1DBC fo
r process 250
Feb 2 09:38:35 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:35 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:35 CST: TFTP: Sending error 1 No such file
Feb 2 09:38:39 CST: TFTP: Server request for port 1024, socket_id 0x489A3B7C fo
r process 250
Feb 2 09:38:39 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:39 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:39 CST: TFTP: Sending error 1 No such file
Feb 2 09:38:43 CST: TFTP: Server request for port 1024, socket_id 0x496F1DBC fo
r process 250
Feb 2 09:38:43 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:43 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:43 CST: TFTP: Sending error 1 No such file
All possible debugging has been turned off
Feb 2 09:38:48 CST: TFTP: Server request for port 1024, socket_id 0x489A3B7C fo
r process 250
Feb 2 09:38:48 CST: TFTP: read request from host 192.168.7.101(1024) via FastEt
hernet0/0.1
Feb 2 09:38:48 CST: TFTP: Looking for WLAN0021A0244B35.xml
Feb 2 09:38:48 CST: TFTP: Sending error 1 No such file
Thanks for the reply though
Kenneth Mohammed Mon, 02/02/2009 - 08:01
Under telephony-services try this:
config t
telephony-service
create cnf-files
Then try to register phone again.
Hope that helped, if so please rate.
kelvin.blair Mon, 02/02/2009 - 08:17
Was this phone working before and you upgraded the firmware and now its not. If it never worked before, is the phone getting the correct IP information? TFTP, Gateway etc....
joshehaos Mon, 02/02/2009 - 08:36
The original phone was a 7921, it broke and so we got a new one. It has the same info as the old one as far as TFTP, IP addressing and gateways go.
thanks for the response but I tried this earlier, just did not post it.
paolo bevilacqua Mon, 02/02/2009 - 08:53
  • Hall of Fame,
    Founding Member
Which IOS are you using ? I'm seeing strange TFTP trouble with 12.4(20)T1
