6500 Bootvar
Feb 2nd, 2009
The bootvar are not the same for the VSS 6500s. Specifically the CONFIG_FILE and BOOTLDR indicate "variable does not exist" on the active unit but show "=" on the standby. This VSS system is working ok but trying to figure out the differences and how to correct them.
(Is this an SP or ROMMON setting?) These are new units.
Joe
vss#sho boot
BOOT variable = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby is up
Standby has 1048576K/65536K bytes of memory.
Standby BOOT variable = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI.bin,1;
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
smalkeric Sat, 02/07/2009 - 14:47
  • Silver, 250 points or more
No this is not an issue. This statement means that the CONFIG_FILE variable is not set manually and will store the configurations on the NVRAM.
jtorjman Sun, 02/08/2009 - 08:24
Thanks. I was just trying to get both sups to show the same thing. (Customer has another VSS where both switches show the same thing.)
Thank you again.
Joe
