Per Vlan Management IP@
Feb 2nd, 2009
For an L2 switch is it possible to define one IP@ for each vlan used on that switch ?
And best practice is to use one single IP@ for management of an L2 switch or one IP@ per vlan ?
Overall Rating: 3.5 (2 ratings)
Tshi M Mon, 02/02/2009 - 07:36
  • Silver, 250 points or more
A layer 2 switch will typically have one IP address for management.
Giuseppe Larosa Mon, 02/02/2009 - 07:45
  • Hall of Fame,
    Founding Member
a l2 switch can have only one management vlan.
I saw this on C2950 when you define a second SVI the first one is put in shudown.
if you enable the one disabled the second is shutted.
if the device is L3 capable but acts as a L2 switch it could have multiple SVIs but there is no need for this as Etienne noted
Hope to help
Giuseppe
badalam_nt Mon, 02/02/2009 - 07:50
And is it recommended to always use vlan 1 for defining management IP@ ? Or better a separate dedicated vlan, which is not used for any other traffic except for remote connection to the switch?
Tshi M Mon, 02/02/2009 - 07:55
I usually avoid to use VLAN1 and create a specific VLAN for management.
badalam_nt Mon, 02/02/2009 - 07:45
So to define one management IP@ per vlan is not recommended?
Giuseppe Larosa Mon, 02/02/2009 - 08:17
  • Hall of Fame,
    Founding Member
Hello Badalam,
use only one different from Vlan 1 and different from vlans where end users connect.
The suggestion is that every campus should have a dedicated management vlan to reach all devices.
This is for telnet/ssh and snmp, syslog and so on.
using vlan1 is not recommended for security reasons.
Having a dedicated management vlan can help keep devices reachable while there are problems on user vlans
Hope to help
Giuseppe
glen.grant Mon, 02/02/2009 - 09:12
  • Purple, 4500 points or more
Vlan1 is also used for control plane traffic such as cdp , vtp etcc so it is better not to run production traffic across vlan 1. It can be any other vlan.
