Rate-Limit L-2 unknowns NOTICE MESSAGE
Feb 2nd, 2009
  • Bronze, 100 points or more
To cut down on excess trash traffic, we want to rate-limit unknown unicasts.
The Cisco doc does not speak to real-world usage and does not mentions all the details as shown by the NOTICE message received when trying to configure rate-limiting.
ANYONE know what PVL is and how to go about configuring it? Also, anyone have real world experience with this feature enabled? PLEASE share!!!!
A-SUP-720-10G(config)#mls rate-limit layer2 unknown 1000 20
%PVL needs to be enabled on routed port, otherwise, rate-limiting might be inaccurate
THANKS
Frank
Giuseppe Larosa Mon, 02/02/2009 - 08:11
  • Hall of Fame,
    Founding Member
Hello Frank,
the warning advices that to implement a rate-limit with accurate behaviour you should implement it inside a routed port (physical or SVI)
by setting this command in global config you would like to implement the control at the global level and the system advertise you that doing so is less accurate.
The feature you are configuring is a form of protection of main cpu
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/dos.html#wp1141218')">http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/dos.html#wp1141218
I think the way you are doing it is the correct one.
I would ignore the warning after having seen the document above.
Hope to help
Giuseppe
