02-02-2009 09:43 AM - edited 03-15-2019 03:55 PM
We're interested in wireless phone for CUCM 6.0 for a healthcare environment and wondering if anyone can recommend a durable handset. We use the 7921 but find that it is not quite durable.
Solved! Go to Solution.
02-02-2009 04:29 PM
You may want to look at the 7925. They have improved the durability quite a bit compared to previous versions. They are targeting it directly at healthcare environments since it is sealed and can be cleaned/sterilized.
http://cisco.com/en/US/products/ps9900/index.html
The BU is also partnering with zCover to provide various accessories, including silicone shock absorbers: http://www.zcover.com/zCover_index_Cisco.htm
02-02-2009 10:46 AM
Hi, if you enter "wireless ip phones" in the popular search engine, the first result is one reputable vendor that has a good selection.
02-02-2009 10:56 AM
Noooo, the result you will get back is a list of ALL vendors looking to sell what I'm looking for. I asked for a recommendation, not directions on how to use a search engine.
02-02-2009 11:56 AM
What I'm trying to tell you, is that the largest selection of phones is found with the steps above - voipsupply.com
02-02-2009 04:29 PM
02-02-2009 05:26 PM
Perfect, thank you.
