Clear Channel parametes
Feb 2nd, 2009
Hello
On a particular place in the building we had a very low throughput on channel 1. We use the 802.11G band.
Using a sectrum analyzer we found in the middle of channel 1 a non 802.11 compliant device transmitting on a very high duty cycle. This explained our problem.
The frequency band used by the device was very narrow (a spike in the middle of channel 1) , signal strength was around -84db ( noise level -80db)
Config is a 4404 Wireless Lan Controller and 1130 access points.
Question: Are there parameters in the WLC available to tweak this behavior, to prevent a relatively weak signal to monopolize the band.
A parameter like: a threshold on RSSI, it should be better than value X to make the channel marked as busy.
Or is everything tight up into the 802.11 MAC en PHY specs?
I was searching for these values but unable to find. The only point where CCA was mentioned was in a Picocell environment
Regards Gerrit
carenas123 Fri, 02/06/2009 - 06:27
  • Silver, 250 points or more
To specify the minimum receive signal strength indication (RSSI) value for packets that are received by an access point, use the config advanced 802.11 coverage rssi-threshold command.
config advanced 802.11{a | b} coverage {data | voice} rssi-threshold rssi
Carenas,
What version of controller code is this command found in? I don't see it in 4.2.112. Is this really the same as a Clear Channel Energy Assessment, and wouldn't this induce unnecessary errors and retries anyway? The clients would need the same value as well would they not?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
