1130AG no signal
Answered Question
I have set up a 1130ag as an access point and the laptops (one xp and one vista) cannot find the SSID. If I manually add the SSID it works fine. The radio is enabled, the interface is up and I have tried manually switching channels without any luck. I am missing something somewhere. Any ideas?
Correct Answer by Scott Fella about 8 years 1 month ago
Under the dot11radio 0 or dot11radio 1 enter:
guest-mode
That will broadcast the ssid if your ap is autonomous.
If you have a wlc, then under the wlan ssid, enable the checkbox for broadcast.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Mon, 02/02/2009 - 13:01
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
guest-mode
Leo Laohoo Mon, 02/02/2009 - 13:02
  • Hall of Fame,
    2017 LAN, Wireless
Is the SSID Broadcase disabled by any chance?
