High input discard rate on interface sc0.
Answered Question
Feb 2nd, 2009
I am getting this error on my 6509 sw, any idea ?
"High input discard rate on interface sc0. The inDiscardRateState transitioned from NOMINAL to HIGH due to a measured value of 1.000322684737012, which is between the lower bound of 1.0 and the upper bound of 100.0. The date and time of the measurement is 2009-02-02T19:37:51.797+0000.
High input discard rate on interface sc0. The inDiscardRateState transitioned from NOMINAL to HIGH due to a measured value of 1.000322684737012, which is between the lower bound of 1.0 and the upper bound of 100.0. The date and time of the measurement is 2009-02-02T19:37:51.797+0000."
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Mohammed,
one or few packets have been discarded on management interface sc0 going over the lower threshold.
This should be a simple notification if you can still reach and manage the device you can ignore it.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 02/03/2009 - 00:01
  • Hall of Fame,
    Founding Member
Hello Mohammed,
Hope to help
Giuseppe
