Splitting Gateway functions over MAN link
Answered Question
I am looking at separating the gateway function into two separate routers. One router will sit in my office (3845) and will terminate all FXS connections. The second will sit in a data center and will terminate 3 x pri's. Both sites will be connected with a 1 GB MAN connection. All calls will route over the MAN link to the gateway in the datacenter. Does anyone see any issues with this design?
Correct Answer by paolo bevilacqua about 8 years 2 months ago
Absolutely no issues.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Mon, 02/02/2009 - 13:09
  • Hall of Fame,
    Founding Member
