Faxserver: Interaction between Rightfax 9.3 and ATA 186, anyway for work?
Feb 2nd, 2009
the customer is installing Rightfax 9.3 this is working fine with gateway supporting T.38 and also there are ata 186 distribuited in four location they dont want to remove it. so is there anyway for work with both solution faxing from ATA 186 to RightFax and RightFax to ATA 186 by WAN? I think this is not posible because RightFax only work with T.38 while ATA 186 only support pass-trought, is correct?
Pablo
goranpilat Tue, 02/10/2009 - 07:54
So you say it is not possible to send fax one to another?
some additional gateways? with dial-peers one side with t38 and other fax pass-through, or something like that?
regards,
Goran Pilat
meballard Thu, 02/12/2009 - 21:06
When you say don't want to remove, do you mean they need the functionality of the ATA there, or they just don't want to touch them. If they are willing to replace it with another device, I believe the VG202 would provide the t.38 functionality and provide effective replacements for the ATA.
goranpilat Thu, 02/12/2009 - 23:20
I meant they don't want to change their ATAs (some of them, of course) either for softfax or VG202, they'll keep ATAs.
So I suppose this wouldn't work..
cheers,
Goran pilat
Pablo Roman Reinoso Fri, 02/13/2009 - 05:06
As i said the requirement was faxing compatibility among ATA and Faxserver, but this is not possible. One solution is replacing ATA by VG202 or VG204 this devices support T.38.
Thanks to everyone for your reply.
Pablo
