match Content-Type: multipart/alternative;
Feb 2nd, 2009
we´re doing a 30 Day trial and we´re trying to migrate functions out of our Surfcontrol EF to 2 Ironport C-150.
add_txt_footer:
[Sender is stadthalle.com] and
["Content-Type: multipart/alternative;" is not in Header] and
["aw:, re:, fwd:, wg:" is not in Subject] and
["7999979" is not in Body] and
[Message < 50kBytes] then add txtfooter
add_html_footer:
["Content-Type: multipart/alternative;" is in Header] and
[Message < 50kBytes] then add htmlfooter
- how can we do that?
Current situation:
add_txt_footer: if (mail-from == "stadthalle.com$") AND (header("Content-Type:") != "multipart/alternative;") AND (body-size < 50000) { add-footer("txtfooter"); }
allways matches, so RTF and HTML Mails dont get the html footer
</PRE>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
<font face="Trebuchet MS"><strong>MASTERS OF DIRT:</strong>
<br>
21. + 22. Februar 2009 / Wiener Stadthalle
<br>
INFO: <a href="http://www.stadthalle.com">http://www.stadthalle.com</a> 01 / 79 999 79 </font>
</body>
</html>
<PRE>
any suggestion welcome!
Klemens
Douglas Hardison Tue, 02/03/2009 - 16:28
  • Cisco Employee,
Hi Klemens,
I made some slight modifications to your posted filter, and tried out my versions on an IronPort, which good results.
There are other options you will probably want to add, such as including the name of the outgoing listener to keep messages from being "double-footered".
This is covered in a Knowledge Base article already: http://tinyurl.com/5gaj24
I created the following as message filters from the CLI.
addtxtfooter:
if(mail-from == "example.com$") AND (header("Content-Type") != "multipart/alternative") AND (body-size < 50000)
addhtmlfooter:
if(mail-from == "example.com$") AND (header("Content-Type") == "multipart/alternative") AND (body-size < 50000)
add-footer("htmlfooter");
Hope that helps.
-whardison
Klemens Untner_... Sun, 02/08/2009 - 09:21
Hello whardison!
we replaced the outgoing Filters with a CLI Filter:
eventinfo:
if ((mail-from == "mydomain.com$") and (not(body-dictionary-match("words", 1))) and (body-size < 50000))
if (header("Content-Type") != "multipart/alternative;")
else
{ add-footer("htmlfooter"); }
the words dictionary contains the following items:
aw:, fwd:, wg:, re:, Converted from text\0x2frtf format
the last entry is needed for some special Outlook rtf circumstances, where the Exchange 2003 is converting the RTF to text due it is mutlipart/alternative. - No Footer
For a new Problem "Group Matching LDAP" i created a new topic 1199
