"Not every router can act as a TFTP server"
Feb 2nd, 2009
  • Bronze, 100 points or more
Is there any truth to this claim?
Specifically we're talking about a 2501 whose show version output appears below.
The eBay seller claims "I have always used tftp to push from the routers out not in the conf t mode because not all routers support being a tftp-server"
I think that's probably bs; when we're talking about a 2501 running IOS 12.3.
Router>sh ver
IOS (tm) 2500 Software (C2500-IS-L), Version 12.3(24), RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 18-Oct-07 13:41 by stshen
Image text-base: 0x0307E1D8, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTLDR: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTW)
Router uptime is 1 hour, 31 minutes
System image file is "flash:c2500-is-l.123-24.bin"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 06250764, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Router>
CriscoSystems Tue, 02/03/2009 - 10:52
I've read instead that on the 2500 series, IOS is both stored in, and executed from, Flash.
glen.grant Tue, 02/03/2009 - 16:20
  • Purple, 4500 points or more
It should read any "modern" router can be a tftpserver . Even low end switches like a 2950 support that function . A 2500 is from the mid 1990's so its way out of date.
Leo Laohoo Tue, 02/03/2009 - 19:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you use the following command in global configuration mode:
tftp-server flash:
CriscoSystems Fri, 02/06/2009 - 15:43
Yes, I have used it.
The available parameters are listed as
null:
nvram:
system:
"flash:" is, I think bizarrely, NOT an option. Whereas I can tftp-server any flash files with any of my _older_ IOS images.
