Logging port activity
Feb 2nd, 2009
I am trying to troubleshoot my VoIP phone not powering up when I connect it to my fa 0/1/0 on a 3825 with an HWIC-D-9ESW with the PoE option installed. The phone used to work but just stopped. When I plug it into any port on the HWIC the power LED blinks about once every 6 seconds. I would like to see if I can capture any logging the port is doing to further analyze this problem.
Appreciate any help.
Leo Laohoo Mon, 02/02/2009 - 19:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Does the HWIC-D-9ESW have an optional power module to provide inline power for IP telephones?
What is the output to the command: sh power inline
kirbyw001 Mon, 02/02/2009 - 20:28
It the HWIC does have the inline power supply for IP phones. In fact this phone used to work on in this current configuration.
When I do "sho power inline" I get the output below.
sho power inline
PowerSupply SlotNum. Maximum Allocated Status
INT-PS 0 360.000 0.000 PS1 GOOD
Interface Config Device Powered PowerAllocated
Fa0/1/0 auto Unknown Off 0.000 Watts
Fa0/1/1 auto Unknown Off 0.000 Watts
Fa0/1/2 auto Unknown Off 0.000 Watts
Fa0/1/3 auto Unknown Off 0.000 Watts
Fa0/1/4 auto Unknown Off 0.000 Watts
Fa0/1/5 auto Unknown Off 0.000 Watts
Fa0/1/6 auto Unknown Off 0.000 Watts
Fa0/1/7 auto Unknown Off 0.000 Watts
kirbyw001 Mon, 02/02/2009 - 20:29
The VoIP telephone is currently connected to fa 0/1/7.
Leo Laohoo Mon, 02/02/2009 - 20:47
  • Hall of Fame,
    2017 LAN, Wireless
What is the IOS and feature of the router?
Leo Laohoo Mon, 02/02/2009 - 20:50
  • Hall of Fame,
    2017 LAN, Wireless
"The phone used to work but just stopped.", have you tried other phones? Have you tried to plug this phone to other PoE ports? Have you tried using a power brick?
Leo Laohoo Mon, 02/02/2009 - 20:52
  • Hall of Fame,
    2017 LAN, Wireless
Please refer to the following link:
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic.html#wp1043334
"There is no inline power on the ninth port (port 8) of the HWIC-D-9ESW card."
Can you try to move the phone to a different port?
kirbyw001 Mon, 02/02/2009 - 20:57
The IOS is 12.4
I have tried this phone and a spare in multiple ports except fa 0/1/8 since it is not PoE capable. Also I have tried both phones on other PoE devices and they work fine. As for a power brick, I do not have one available.
Leo Laohoo Mon, 02/02/2009 - 21:04
  • Hall of Fame,
    2017 LAN, Wireless
So basically, if you plug this (and only this) phone to any other ports, it won't power up but other phones will. Is this correct?
kirbyw001 Mon, 02/02/2009 - 23:22
no phone would power up on this router but would on another PoE device.
However, I found my problem....it turned out to be two faulty ethernet cables that would work for a PC but would not provide PoE for my VoIP. What pins on the ethernet cable is the power on? Does it travel the same pins as the RX/TX data (1, 2, 3, & 6)?
Leo Laohoo Tue, 02/03/2009 - 19:07
  • Hall of Fame,
    2017 LAN, Wireless
PoE uses pin 4 & 5.
