Replace analog modem dial-up line with router leased line
Answered Question
Feb 2nd, 2009
Here is my situation. I am trying to replace existing modem dial-up connection that looks something like this -
Local PC --- Modem (Ext.) --- phone line --- Modem (Ext.) --- Remote Repeater Station
The Local PC will dial into the Remote Repeater Station (RRS) to perform configuration tasks. It is able to dial into any RRS that has a modem attached one at a time.
My objective is to be able to perform the same configuration tasks without the modems and phone line. I have already established a router-leased line-router connection between the local and remote sites. Can you tell me what Cisco Card/Module/Cable/etc is necessary for me to use and the configuration needed on the routers?
Thanks.
Correct Answer by Paolo Bevilacqua about 8 years 2 weeks ago
Very good. Remember to rate useful posts with the scrollbox below.
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Tue, 02/03/2009 - 03:04
Please explain in detail what is that you have "already established", and why you are asking since you have "already established".
pllim Tue, 02/03/2009 - 17:47
I have only connected the two routers together over a leased line. Both routers can communicate (PING) with each other. The PC and RRS are not connected to the routers.
pllim Tue, 02/03/2009 - 17:52
I am doing this test in a lab environment. The 2 routers are connected using their Ethernet port via a UTP cable. Both routers are also installed with Async/Sync serial network module.
Router A - IP address 10.80.1.1/16
Router B - IP address 10.80.1.2/16
pllim Wed, 02/04/2009 - 17:18
I would like to connect a PC to the Local Router and the RSS to the Remote Router? The RSS has a Serial DB25 (female) port that acts like a Cisco Console port.
I need the PC to be able to connect to the RSS to perform configuration tasks on the RSS. Can you tell what Cisco card/module/cable/etc are required? Also, what is the configuration on the Cisco Routers?
Thank you.
Paolo Bevilacqua Wed, 02/04/2009 - 19:54
On the remote router, do sh line to see which line you have connected the rss. From the pc, telnet to port 2000 + line number. You can search for "terminal server" in the documentation.
