Jaime Valencia Tue, 02/03/2009 - 07:33
  • Cisco Employee,
  • Hall of Fame,
    2011
i'm going to assume this is for CUCM as you don't mention anything of what products you're using
multitenant design is based simply on using CSS and partitions to separate each company, there's nothing more to it on CUCM.
PT1/CSS1 for company 1
PT2/CSS2 for company 2
PT3/CSS3 for company 3
java
if this helps, please rate
shaishav.parikh Tue, 02/03/2009 - 07:47
Thanks for the reply this design is correctly right what i want is to design unified/distributed dial plan for the tenants .. hence i was looking for some standard abbrivations and if some simple document available
regards
