Cache Engine 500 - problem with websites loading
Answered Question
Feb 3rd, 2009
I'm using Cisco Cache Engine 500 and I have some annoying problem. Surfing on the Internet is horrible, website either not loading at all or loading after hundreds of refreshes. Sometimes, when I have two tabs opened in my browser, first with for example cisco.com website, when I'm trying to open different site on the second tab it also opens cisco.com. Here also refresh helps and after few F5's I have a proper website on the other tab.
Anyone had problems like this? Is there any way to check if it is cache problem for sure?
Correct Answer by smahbub about 8 years 2 weeks ago
set the following command in the CE and then try again?
CE (config)#no http persistent-connections all
And also test the following step by step?
1- Use the command: http object url-validation enable
2- Disable rules with no rule enable
3- Remove url-filter
Overall Rating: 5 (1 ratings)
Correct Answer
smahbub Mon, 02/09/2009 - 15:50
gornikfan Thu, 02/26/2009 - 02:49
THANKS! It's working :)
This command solved my problem:
