ISDN PRI dialing to multiple locations
Feb 3rd, 2009
Hi all, if im in the uk and I want to dial to multiple locations on my isdn30 pri circuit, how do I seperate each channel, and do I associate each channel to a dialler interface?
can someone give me an example config of this, where it can dial say 3 different places each at 64k each
cheers
carl_townshend Tue, 02/03/2009 - 03:43
Hi there, sorry, this is for BRI, i need the one when using ISDN30 PRI
cheers
Carl
paolo bevilacqua Tue, 02/03/2009 - 03:51
  • Hall of Fame,
    Founding Member
It's the same configuration, beside if you search in the box top right corner, you will find example with PRI as well.
