Incoming CALL
Feb 3rd, 2009
hi,
i have configured a H323 getaway with a Cisco unified 7.0.
for the all incoming call i configured that to be destined to the extension number 1000 .
but if i change the partition + CSS form NONE , no incoming call is ringing.
also want to enable the caller id for the incoming call??
the IOS version is (C2800NM-IPVOICEK9-M), Version 12.4(22)YB.
Many thanks in advance
Jaime Valencia Tue, 02/03/2009 - 07:30
  • Cisco Employee,
  • Hall of Fame,
    2011
dial-peer voice 1001 voip
destination-pattern 1000
progress_ind setup enable 3
session target ipv4:192.168.31.2
dtmf-relay h245-alphanumeric
codec g711ulaw
that's the dial-peer you're using, that simply tells which CUCM to send the H225 signaling. in CUCM you still need to have a valid incoming CSS configured under the H323 GW to reach DN 1000 on whatever partition it is
java
if this helps, please rate
