How to create dial-peer that is similar to route pattern like this?
Answered Question
Feb 3rd, 2009
I have route pattern <font color=red>0[1234]</font> for urgent calls with MGCP gateways.
Now I have changed this numbering plan
from <font color=red>0[1234]</font> to <font color=red>#.10[1234]</font> with Predot Discard Digits for MGCP gateway.
But I also have H.323 gateways.
What right dial-peer should I use in this position?
The old dial-peer is below.
<b>
dial-peer voice 5 pots
tone ringback alert-no-PI
destination-pattern 0[1234]
no digit-strip
direct-inward-dial
port 0/0/0:15
</b>
How I should change it to receive same result that I described for Route Patter?
Correct Answer by Nicholas Matthews about 8 years 3 months ago
dial-peer terminator *
destination-pattern #10[1234]
forward-digits 3
direct-inward-dial
port 0/0/0:15
The # is the default terminator and would cause problems. You want 3 digits in this case, so you use forward-digits 3.
-nick
Overall Rating: 5 (1 ratings)
Correct Answer
Nicholas Matthews Tue, 02/03/2009 - 05:42
  • Red, 2250 points or more
forward-digits 3
direct-inward-dial
port 0/0/0:15
-nick
webstd.design Tue, 02/03/2009 - 06:07
as I understood from this command dial-peer terminator * I should use #
Like this one dial-peer terminator #
Nicholas Matthews Tue, 02/03/2009 - 06:51
You can try it - but I believe if you try using the terminator in your dial string, it may not act accordingly.
In this case we're changing the default terminator so that you can use it in your dial strings. I haven't tried it, so you may want to try it first without the change. You wouldn't need your command, because # is the default terminator.
hth,
nick
