Command reference Guide for ssh (Cisco 7941g)
Where I can found the command reference guide for IP Phone 7941g in order to remotely modify the configuration of a Cisco IP Phone 7941g?
Thank you.
Best regards.
Massimiliano.
paolo bevilacqua
You cannot modify the configuration of a phone via SSH. The access and commands are not documented.
Configuration and settinga are made exclusively with the .xml files that the phones loads via TFTP at boot.
paolo bevilacqua
Thank you.
Best regards.
Massimiliano.
You are welcome.
Thanks for the nice rating and good luck!
