ASA5505-SEC-BUN-K9 Connecting VPN client to ASA
Feb 3rd, 2009
we are facing problem while installing ASA5505-SEC-BUN-K9.
Type of Problem :
WE HAVE SETUP THE REMOTE VPN AND GIVEN ALL THE INFO WHAT IS TOLD IN MANUAL . BUT STILL WHEN I TRY TO PING FROM MY SYSTEM TO MY ASA IP [ OUTSIDE ] IT DOES NOT PING . AS A RESULT THE VPN CLIENT IS NOT ABLE TO CONNECT TO ASA.
Pls help.
Thanks & Regards
Ivan Martinon Tue, 02/03/2009 - 09:25
Can you post your ASA config on the forum? also go ahead and check the interface state of the ASA with the show interface command, is it up? Does your ASA have default gateway? Can your ASA ping this default gateway?
pradeepsamant Fri, 02/20/2009 - 03:09
Pls chk answer of your queries.Pls chk attached ASA config.
a)interface state of the ASA with the show interface command, is it up?Answer is YES
b)Does your ASA have default gateway?
d) Can your ASA ping this default gateway?Answer is YES
Thanks & Regards
Ivan Martinon Fri, 02/20/2009 - 08:28
Go ahead and get rid of the authorization lines on your tunnel group:
tunnel-group madhu general-attributes
address-pool rmt
authorization-server-group LOCAL
authorization-server-group (outside) LOCAL
no authorization-server-group LOCAL
no authorization-server-group (outside) LOCAL
no authorization required
Make another test with all of those out.
pradeepsamant Sat, 02/28/2009 - 03:39
But by this every one who has ip can acess the vpn and how customer will control acess of vpn by authorised users.
Ivan Martinon Mon, 03/02/2009 - 07:09
If you have a user account on either the ASA or an external server and that is checked when using the vpn client, then only users that have valid username and password will be able to connect.
pradeepsamant Tue, 03/03/2009 - 00:22
Thanks & Regards
