Extending AD for Unity 7 when Unity 4 is already present
Answered Question
Feb 3rd, 2009
My situation is that one of the sites in my client's enterprise already has Unity v4.0.5, and works fine the AD was previously extended.
Question: we're now adding Unity v7, does the AD have to be extended again? Or is the existing AD good enough? If it has to be extended again, how will it affect the existing Unity v4.0.5 installation?
Thanks, Jeff
Correct Answer by Jaime Valencia about 8 years 5 months ago
you do have to extend the schema, the schema only adds info, it does not remove anything and is backwards compatible. it will only add fields to be used by 7.x which will be transparent to 4.x
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 02/03/2009 - 07:27
  • Cisco Employee,
  • Hall of Fame,
    2011
java
