C3560G not showing boot system after image installed
Feb 3rd, 2009
I recently downloaded a new IOS c3560-ipbasek9-mz.122-46.SE.bin onto one of my 3560. I then entered the command boot system flash:c3560-ipbasek9-mz.122-46.SE.bin but when I do sh run | i boot, I don't see the line. I don't see it either when I do sh run. I just don't know why the line boot system flash:... is not showing. Any ideas?
Tshi M Tue, 02/03/2009 - 05:58
the current path for the existing IOS is:
However, I downloaded the image to the flash: and below is the sh flash: output
Directory of flash:/
2 -rwx 916 Feb 28 1993 19:02:34 -05:00 vlan.dat
3 -rwx 8811199 Feb 2 2009 20:58:12 -05:00 c3560-ipbasek9-mz.122-46.SE.bin
4 -rwx 27 Feb 2 2009 21:19:22 -05:00 private-config.text
6 drwx 192 Feb 28 1993 19:08:50 -05:00 c3560-ipbase-mz.122-25.SEE3
410 -rwx 12643 Feb 2 2009 21:19:22 -05:00 config.text
davy.timmermans Tue, 02/03/2009 - 06:10
the current image is installed via archive download-sw. (.tar file)
Can you try if it make a difference if you do ":/"
boot system flash:/c3560-ipbase-mz.122-25.SEE3
else you can delete the directory of the current installed file. recursive deletion is required. Otherwise you've to delete first all files in the directory c3560-ipbase-mz.122-25.SEE3, before you can delete the folder itself:
delete /force /recursive flash:c3560-ipbase-mz.122-25.SEE3
The reason that c3560-ipbase-mz.122-25.SEE3/c3560-ipbase-mz.122-25.SEE3.bin is been used is because there's no correct boot system file statement(?). Now it looks during startup for the first bin in flash (alphabetically)
Tshi M Tue, 02/03/2009 - 06:17
I actually try
boot system flash:/c3560-ipbasek9-mz.122-46.SE.bin but to no success either. I don't want to delete the current IOS and its directory as they don't cause any problems (i.e. not enough space). I have done this several times before and never ran into this problem.
davy.timmermans Tue, 02/03/2009 - 06:19
Can you watch during reboot to the output in your console?
for a "could not find flash: " message or something like this?
Tshi M Tue, 02/03/2009 - 06:23
I will give it a stab later on today. I just don't understand why the line is not showing up in the config. The switch doesn't return anything when I entered that command. It takes it just fine.
Tshi M Tue, 02/03/2009 - 06:27
well...an interesting thing is that the show boot command return the boot path-list with the new IOS.
BOOT path-list : flash:/c3560-ipbasek9-mz.122-46.SE.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
So, I guess it should boot to the new IOS upon restart.
davy.timmermans Tue, 02/03/2009 - 06:28
can you follow the at the console during reboot?
When it's not ok, he will say something like:
cannot find flash:xxxx ; look for first file in flash
if it's ok, then, it's ok:)
glen.grant Tue, 02/03/2009 - 07:33
That is normal for these switches , it will "not" show up in the running config . Just verify with the "show boot" command after entering your boot statement . It will tell you which file it is going to load . The boot statement is actually stored in one of the other files in flash , might be the private-config file but I won't swear to it .
Tshi M Tue, 02/03/2009 - 07:36
Hi Glen,
Thanks indeed, yes I discovered it earlier.
Tshi M Tue, 02/03/2009 - 08:37
I have yet to reload the IOS and I am sorry if I did not explain the problem properly. What I meant to say that I didn't want to reload the router because the line boot system flash:.... was not present in the config file. However, after using the command sh boot, I discovered that the boot path is pointing to the new IOS. So, I will reload the device this evening.
