Access Control System Services
Feb 3rd, 2009
The services in the ACS are not running in the Computer Management / Service, the status of the services are:
CSAdmin (Stop, not initialized)
CSAuth (Stop, not initialized)
CSDbSync (Stop, not initialized)
CSLog (Stopping)
CSMon (Starting)
CSRadius (Starting)
CSTacacs (Stop, not initialized)
When I try to Star these service these message are showed:
CSTacacs (Stop, not initialized):
Windows could star the CSTacacs en Local Computer. For more information, review the System Event Log. If ths is a non-Microsoft service, contact the service vendor, and refer to service-specific error code 1066.
The CSDbSync service on Local Computer started and then stopped. Some service stop automatically if they have no work to do, for example, the Performance Logs and Alerts service.
Windows could star the CSAuth on Local Computer. For more information, review the System Event Log. If ths is a non-Microsoft service, contact the service vendor, and refer to service-specific error code 74.
The CSAdmin service on Local Computer started and then stopped. Some service stop automatically if they have no work to do, for example, the Performance Logs and Alerts service.
How I can Start these service ?
Thanks.
ACS version 4.0
Microsoft Windows Server 2003
Ivan Martinon Tue, 02/03/2009 - 09:34
Is this Windows Box having a service pack installed? say service pack 2? What was made to make this services not to start? Is this a new installation, was it working before or was any patch applied?
