ACS Services
Feb 3rd, 2009
The services in the ACS are not running in the Computer Management / Service, the status of the services are:
CSAdmin (Stop, not initialized)
CSAuth (Stop, not initialized)
CSDbSync (Stop, not initialized)
CSLog (Stopping)
CSMon (Starting)
CSRadius (Starting)
CSTacacs (Stop, not initialized)
When I try to Star these service these message are showed:
CSTacacs (Stop, not initialized):
Windows could star the CSTacacs en Local Computer. For more information, review the System Event Log. If ths is a non-Microsoft service, contact the service vendor, and refer to service-specific error code 1066.
The CSDbSync service on Local Computer started and then stopped. Some service stop automatically if they have no work to do, for example, the Performance Logs and Alerts service.
Windows could star the CSAuth on Local Computer. For more information, review the System Event Log. If ths is a non-Microsoft service, contact the service vendor, and refer to service-specific error code 74.
The CSAdmin service on Local Computer started and then stopped. Some service stop automatically if they have no work to do, for example, the Performance Logs and Alerts service.
How I can Start these service ?
Thanks.
ACS version 4.0
Microsoft Windows Server 2003
cisco24x7 Tue, 02/03/2009 - 07:06
  • Silver, 250 points or more
Depending on the Windows 2003 and Service
Pack level, ACS 4.0 is NOT supported per
my conversation with Cisco TAC
ricardorojas123 Tue, 02/03/2009 - 08:48
And What can I do ? ...
... To restore the normal operation of the Windows services associated with the ACS, can I reinstall the ACS application?. Reinstalling the application, I lose the configuration of the ACS?
Jagdeep Gambhir Tue, 02/03/2009 - 09:32
  • Red, 2250 points or more
If you have backup try to reinstall acs software. Else you will loose acs configuration since only way is to reinstall acs. But still there is no guarantee that it will work fine since it is running on unsupported platform.
~JG
Do rate helpful posts
ricardorojas123 Tue, 02/03/2009 - 12:12
Hi, the server has been operating 1 years. Three days ago the state of services has changed.
Jagdeep Gambhir Tue, 02/03/2009 - 12:17
I agree, even I have seen it working on unsupported platform. It will work but there is not guarantee that it will continue to do so. It will surely give you abnormal results.
~JG
ricardorojas123 Tue, 02/03/2009 - 16:51
Ok ,
But jgambhir, If I reinstall the server, the configuration, the database of AAA clients and and the certificates installed will be lost?
darpotter Wed, 02/04/2009 - 00:42
Here's something you could try.
1) Set all ACS services to manual start
2) Reboot server
3) In a couple of cmd prompt windows run:
csauth -z
csadmin -z
Fingers x'd they will both run ok from the cmd line.
Then use ACS Admin to get a backup of your config. If that works at least you'll have saved something.
If csauth & csadmin dont want to work at all you could instead use csutil -d to create a dump file. You'd get the user/group database which could be reloaded into a fresh install once you re-created the lost config (network config etc)
