02-03-2009 06:25 AM - edited 03-15-2019 03:57 PM
There is an option to check Call History in GUI page on CME but I don't see call records. How do I set my CME gateway to generate call records?
Reports > Call History
Many thanks,
K
Solved! Go to Solution.
02-03-2009 06:35 AM
Greetings there are a couple of things you need to do before the Call History can be enabled.
Youll need to enter the following commands through the cli.
dial-control-mib retain-timer 10080
dial-control-mib max-size 500
gw-accounting syslog
02-03-2009 06:35 AM
02-03-2009 07:13 AM
That works fine, thank you very much!
