ASA Failover stateful
Feb 3rd, 2009
Hi, two ASA with 7.2.4 and configured stateful failover...should it be regular behavior to drop some tcp connection? I repeat, stateful failover is configured on the same interface as LAN failover, but is it ok that some percent of tcp connection is dropped or it is 100 percent stateful?
Ivan Martinon Tue, 02/03/2009 - 09:29
  • Cisco Employee,
I belive this depends on various parameters, for instance is the platform able to handle the load? if you have a small box and your network is really high and loaded I think it might be normal to drop some state information. It also has to do with the fact that the state link is not dedicated. Is this for http connections?
