Router w/ Dynamic L2L Tunnel and VPN Clients
Answered Question
Feb 3rd, 2009
  • Green, 3000 points or more
I have a 7200 router currently configured w/ vpn clients. I am attempting to add a dynamic l2l tunnel to it. When I do, I am no longer able to connect using the vpn client. I following the configuration in the following url.
http://cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801dddbb.shtml
As soon as I add...
crypto dynamic-map dynmap 5
set isakmp-profile VPNclient
the vpn client no longer works. Don't have access to the config right now as I took it all out. Anyone have this working properly?
Correct Answer by Ivan Martinon about 8 years 3 months ago
OK, mhhh I think it is an issue with the config, give it a shot to one of the L2L that is bouncing, set it to profile and keyring, what is the result.
Overall Rating: 4.3 (3 ratings)
Ivan Martinon Tue, 02/03/2009 - 09:18
  • Cisco Employee,
This configuration should work, we will need to take a look at your config to see what you might be missing, maybe a keyring setup?
acomiskey Tue, 02/03/2009 - 10:23
I will post up the configuration I am using as soon as I can. Thanks for looking.
celiocarreto Wed, 02/04/2009 - 03:25
here is a configuration example:
local-inside: 192.168.1.0/24
vpn-pool: 192.168.3.0/24
remote-site-IP: 192.168.100.0/24
aaa authentication login userauth local
aaa authorization network groupauth local
username clientuser password 0 XXXXX
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key YYYYY address 0.0.0.0 0.0.0.0 <- password for dynamic site-to-site
crypto isakmp client configuration group vpnclient
key ZZZZZZZ
pool vpn-pool
acl 120
crypto isakmp profile VPNclient
description vpnclient
match identity group vpnclient
client authentication list userauth
isakmp authorization list groupauth
client configuration address respond
crypto ipsec transform-set myvpn esp-3des esp-sha-hmac
crypto dynamic-map mymap3 5 <- CLient VPN
set transform-set myvpn
match address 110 <- match VPN-Pool
crypto dynamic-map mymap3 10 <- site-VPN
set transform-set myvpn2
match address 140 <- match internal Site-IP
crypto map mymap 20 ipsec-isakmp dynamic mymap3
ip local pool vpn-pool 192.168.3.1 192.168.3.254
access-list 110 permit ip any 192.168.3.0 0.0.0.255
access-list 120 remark split-tunnel for vpn-clients
access-list 120 permit ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 130 remark no-nat-accesslist
access-list 130 deny ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 130 deny ip 192.168.1.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 130 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 130 interface Dialer0 overload
access-list 140 remark site-IPs
access-list 140 permit ip 192.168.1.0 0.0.0.255 192.168.100.0 0.0.0.255
Regards, Celio
Ivan Martinon Wed, 02/04/2009 - 07:42
  • Cisco Employee,
The reason this does not work is because you have the default key setup:
This key has to be defined in a keyring rather than this here otherwise clients will not connect. Follow the link you pasted and check that they use keyrings for clients and for dynamic clients
celiocarreto Wed, 02/04/2009 - 07:50
Hi Imartino,
this configuration is currently working. But every remote-site has the same password :-)
Regards, Celio
Ivan Martinon Wed, 02/04/2009 - 07:53
  • Cisco Employee,
regardless of every remote having the same password, you need to put this dynamic key into a keyring if this is not done then your clients will not work
acomiskey Fri, 02/13/2009 - 06:16
Back to my original issue here..
I was able to get this working, but now seem to be having issues with my other L2L tunnels dropping out every so often and not coming back up. Anyone ever seen this error before?
Found ADDRESS key in keyring spokes
Feb 13 09:07:00: ISAKMP (0:578): Oops. Used some key with the peer and
Feb 13 09:07:00: when she revealed identity we don't find
Feb 13 09:07:00: hers in the relevant keyring. Thwarting her.
This is what I got when I tried to initiate one of my static L2L tunnels. This tunnel should have nothing to do with the keyring.
acomiskey Fri, 02/13/2009 - 07:56
I can post some...will post back in a little while. thanks.
acomiskey Fri, 02/13/2009 - 08:03
Here is what should be relevant, let me know if you need more.
Ivan Martinon Fri, 02/13/2009 - 08:24
  • Cisco Employee,
I thought this too some time ago, try to get your static lan to lan to use profiles as well with keyrings too, that should fix it
acomiskey Fri, 02/13/2009 - 08:30
Yuck, I was afraid you would say that. There are a lot more vpn's than what I posted. Would adding a "match address" statement somewhere for the dynamic l2l tunnel help at all?
Ivan Martinon Fri, 02/13/2009 - 08:34
  • Cisco Employee,
Unfortunately nope, the problem with dynamic setup and vpn clients comes when the identity is to be negotiated/identified, since both dynamic tunnels and vpn clients would use the "default key" (isakmp key ... 0.0.0.0) then the router would need to know a way to identify each kind of connection vpn clients dynamics hence the use of the isakmp profiles, so as you can see it is a problem with isakmp negotiation rather than ipesc phase 2 negotiation.
acomiskey Fri, 02/13/2009 - 09:06
So the static tunnels I have are landing on the dynamic map 0.0.0.0 before hitting the static ones?
crypto dynamic-map DYNmap 30
set transform-set 3des
set pfs group2
set isakmp-profile L2L
crypto map lim 115 ipsec-isakmp
set peer x.x.x.x
match address 115
reverse-route
Ivan Martinon Fri, 02/13/2009 - 09:15
  • Cisco Employee,
It seems they are not even landing on any tunnel since there is no keyring with what to identify them it does not go further, unless your outputs show something else, show crypto isakmp sa
acomiskey Fri, 02/13/2009 - 09:39
The tunnels are coming up, but they seem to be bouncing up and down.
dst src state conn-id slot
x.x.x.1 192.168.10.1 QM_IDLE 548 0
x.x.x.2 192.168.10.1 QM_IDLE 603 0
x.x.x.3 192.168.10.1 MM_NO_STATE 638 0 (deleted)
x.x.x.4 192.168.10.1 QM_IDLE 629 0
x.x.x.5 192.168.10.1 QM_IDLE 599 0
192.168.10.1 x.x.x.6 QM_IDLE 610 0 L2L
192.168.10.1 x.x.x.7 QM_IDLE 627 0 VPNclient
192.168.10.1 x.x.x.8 QM_IDLE 636 0 VPNclient
x.156.x.157 x.x.x.9 QM_IDLE 639 0
x.71.x.52 x.x.x.10 MM_NO_STATE 637 0 (deleted)
x.201.x.43 x.x.x.11 QM_IDLE 622 0
Correct Answer
Ivan Martinon Fri, 02/13/2009 - 09:45
  • Cisco Employee,
Hello guys
I have a similar problem with Dynamic peers, static peers and VPN clients.
I'm using isakmp profiles and keyrings for dynamic peers and vpn clients but not for that static tunnel.
What happens is that when I try to establish the dynamic tunnel the router asks for XAUTH, which was suppose to be bypassed if I'm not wrong... vpn clients and static tunnel works fine.
Could anyone give me a hint?
Thanks.
Guilherme
acomiskey Fri, 02/20/2009 - 08:19
So far so good. Thanks for the help.
satheesh118 Thu, 02/19/2009 - 18:56
hai,can u please hlep me to create site to site tunnel vpn...
if possible can u please share the doc too.
Ivan Martinon Fri, 02/20/2009 - 08:25
  • Cisco Employee,
Hey, basically you need to create another profile for your static vpn tunnels with a keyring too, follow the doc at the very top of this post just adapt it to your setup.
