7914 expansion module on CCME-the buttons are constantly RED
Feb 3rd, 2009
I have been doing a CME deployment and ran into some problem with the 7914 expansion module on the receptionist's 7961 phone.
I have the following file in flash-S00105000300.sbn
I also have the following configurations:
tftp-server flash:s00105000300.sbn
telephony-service
load 7914 s00105000300
all configurations seem to be ok,but there is no change-the buttons are just stuck in the red color.
Anyone who's gone through this before?
What was the workaround?
Thank you!
Paolo Bevilacqua Tue, 02/03/2009 - 08:14
Which IOS are you using? I'm seeing strange issues with sidecards in 12.4(20)T1.
In some case I had to force the phone to register to another ephone tag. You do this under ephone configuration, reset, set mac to a fantasy number, phone will register to next available ephone, copy all config in there.
Make sure you have auto-reg enable when doing this.
Paolo Bevilacqua Tue, 02/03/2009 - 09:08
I'm hitting this bug exactly. It is a total success killer for those wanting latest CME.
Will be fixed in 12.4(20)T and 12.4(22)T ?
Nicholas Matthews Tue, 02/03/2009 - 09:53
It is fixed into two IOS releases that are currently available:
12.4(20)T2 and 12.4(22)YB. YB is CME 7.1, and T2 just came out yesterday.
hth,
nick
