4900M. Configuration 1GE (RJ45) + 1GE (twingig SFP)
Feb 3rd, 2009
hi, please advice
i need to configure 4900M switch with combination WS-X4920-GB-RJ45 + WS-X4908-10GE cards and i need to use 2x10GE onboard port + 15x1GE copper ports + 6x1GE SFP optic ports (via 3 twingig converters plug into X4908-10GE card).
Do you think it would work or not?
i can't find information about it. Data sheet contains some variety configurations but does not have configuration when it is required to use 1GE (RJ45) on one card couple with 1GE (SFP) on X4908-10GE card + twingig.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
thanks in advance
Giuseppe Larosa Tue, 02/03/2009 - 08:14
Hello Andrey,
configuration has to be done on groups of ports that share the same asic
Switch(config)# hw-module module m port-group p
select [gigabitethernet | tengigabitethernet]
see
http://cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/sw_int.html#wp1077316')">http://cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/configuration/guide/sw_int.html#wp1077316
it explains also how to see port group mappings
Hope to help
Giuseppe
Yudong Wu Tue, 02/03/2009 - 10:36
Yes, it's possible. I don't think Table 2 in data sheet gives all options.
goryachev Tue, 02/03/2009 - 23:25
thanks so much.
one more question:
when i order chassis 4900M with WS-X4908-10GE card, does it include 8 twingig converters (CVR-X2-SFP) or i need to reorder it for special (not zero) price?
