ASR1000 series etherchannel
Feb 3rd, 2009
I tried several methods to do etherchannel on the ASR1006 to 3750 switch.
Method one:
port-channel 1
ip add
int g1/0/51
no switch
channel-group 1
ASR1006 configuration
int port-channel 1
ip add
int G2/1/0
channel-group 1
the port channel would show up but would not negotiate. Could not ping other end.
Other method
Switch config
vlan 2
ip add
switch trunk encap dot1q
switch trunk allow vlan 2
switch mode trunk
ASR 1006 configuration
int g2/1/0
vlan-id 2
this sets up subinterface and the example does no go from there. The router will not let you set up different encapsulations on the sub-interface.
I need a clear example to have two one gig connections from a 3750 switch to an ASR1006 to form a two gig etherchannel
Giuseppe Larosa Tue, 02/03/2009 - 08:00
see the following document ASR1000 is different then other devices about etherchannel
it uses subifs and has the concept of vlan mappings that is different from what we are used to see on switches
if you want to use it for a single vlan it will use a single GE (this was described in another thread)
Hope to help
