ACS Banner (TACACS)
Feb 3rd, 2009
Is there anywhere in Cisco ACS (3.3) where I can set a central Banner message, or a custom login prompt?
I would like to know when I get a login prompt if it is going to authenticate via TACACS or using the local db.
Jagdeep Gambhir Tue, 02/03/2009 - 10:59
  • Red, 2250 points or more
aaa authentication fail-message ^C
aaa authentication password-prompt "Enter local password:"
aaa authentication username-prompt TACISDOWN
~JG
Do rate helpful posts
random_camden Tue, 02/03/2009 - 11:24
Thanks JG.
I can see how that works for failures, but is there any way to set it on the ACS server for if TACACS is available?
Neil
Jagdeep Gambhir Tue, 02/03/2009 - 11:48
Neil,
That you can set up on router itself by this command
TACACS Password Incorrect^
When tacacs is available and you issue wrong password ---> It will prompt TACACS password Incorrect.
IF tacacs is down--->It will prompt tacacsdown.
You will use local password
I don't think we can set it up on acs.
~JG
random_camden Tue, 02/03/2009 - 12:03
Thanks again JG
An ACS solution would be neater, as I have 10,000+ devices to configure, but at least this will give the end result!
Neil
darpotter Wed, 02/04/2009 - 00:47
  • Silver, 250 points or more
I did some googling on this and was horrified to not find anything. RADIUS has the Reply-Message attribute that can do exactly this.
I guess you could to use Cisco Works to push the prompt command out to every device?
