Router doesn't perform EIGRP load metric component calculation
Feb 3rd, 2009
Hi all,
<br />I've try to tune EIGRP to calculate its metric based on load value but it seems doesn't work. My config of EIGRP process is below:
<br />
<br />router eigrp 1
<br /> network 0.0.0.0
<br /> metric weights 0 1 1 1 0 0
<br /> no auto-summary
<br />
<br />After loading the link I saw that load value changed depending on loading but there wasn't any metric changes even after clearing neighbors session.
<br />
<br />R3#show ip eigrp topology 155.1.10.0/24
<br />IP-EIGRP (AS 1): Topology entry for 155.1.10.0/24
<br /> State is Passive, Query origin flag is 1, 1 Successor(s), FD is 39215
<br /> Routing Descriptor Blocks:
<br /> 155.1.13.1 (Serial0/1), from 155.1.13.1, Send flag is 0x0
<br /> Composite metric is (39215/100), Route is Internal
<br /> Vector metric:
<br /> Minimum bandwidth is 256 Kbit
<br /> Total delay is 20100 microseconds
<br /> Reliability is 255/255
<br /> Load is 85/255
<br /> Minimum MTU is 1500
<br /> Hop count is 1
<br /> 155.1.31.1 (Serial0/2.1), from 155.1.31.1, Send flag is 0x0
<br /> Composite metric is (156862/100), Route is Internal
<br /> Minimum bandwidth is 64 Kbit
<br /> Load is 1/255
<br />
<br />It is used c3745-adventerprisek9-mz.124-23.bin software.
<br />
<br />Has anyone faced with such problem?
Giuseppe Larosa Tue, 02/03/2009 - 07:52
  • Hall of Fame,
    Founding Member
Hello Vladimir,
in another thread of some mounths ago Russ White (Cisco Ssytems) explained that current EIGRP implementation is not able to react to load changes on the link.
The load used is the that at the time of enabling EIGRP on the interface.
If after time usage of the link changes the metric doesn't change.
There are plans to implement this he said but with no dates.
Current EIGRP implementations use the standard K values based on BW and delay only.
To be noted that implementation can cause problems:
while the link is empty traffic is moved to the link then the link is full and its metric becomes higher.
So you can imagine what can happen on two parallel links: a poor implementation could cause oscillation of traffic between the two links.
Current implementation is static.
Hope to help
Giuseppe
