CCM 6.1(2) ccmadmin timeout
Feb 3rd, 2009
Recently upgraded to CCM 6.1(2). Is there a way to change the ccmadmin webpage idle timeout. I would like to extend the timeout if possible.
Any help is appreciated
Overall Rating: 5 (2 ratings)
Jaime Valencia Tue, 02/03/2009 - 08:28
not possible:
CSCsj45520
CM 6.0/7.0 Customer should be able to configure/disable CCMAdmin timeout
Symptom:
Browser session to CCMAdmin times out after 30 minutes and user must re-authenticate.
Conditions:
Browser session to CCMAdmin idle for 30 minutes with CM6.x.
Workaround:
None. Reauthenticate after 30 minutes of inactivity.
Further Problem Description:
This is an enhancement request to allow configuration of web session timeout. Please contact Cisco account team or Cisco Product Manager for status, details, and updates about this enhancement request.
java
if this helps, please rate
Rob Huffman Tue, 02/03/2009 - 10:01
Hi Java,
I was not aware of this bug. Nice find my friend, +5 points for your good work!
Cheers!
Rob
