VIP not responding to ICMP
Feb 3rd, 2009
I have 3 VIP's setup on an ACE 4710 Appliance and they are all working correctly. 2 of them I can ping and get ICMP replies back the 3rd (also the busiest) I dont get ICMP replies back. The config is identical between them all as far as adding in the command "loadbalance vip icmp-reply". Anybody else had this problem?
Gilles Dufour Wed, 02/04/2009 - 03:02
  • Cisco Employee,
IS this Layer 3 vip ? Layer 4 vip ? or above ?
Can we see the relevant config.
What version do you run ?
Tx.
Gilles.
celiocarreto Wed, 02/04/2009 - 07:59
check if you have applied an access-list to your OUTSIDE interface.
Regards, Celio
thefindjack Thu, 02/05/2009 - 08:17
This seemed to be a bug in the code, I had to reboot the ACE due to another bug, CSCsv95366, and after the reboot the VIP was replying to ICMP. Thanks for your replies.
