CUCM 6.1 integration with Domino
Jaime Valencia Tue, 02/03/2009 - 08:58
  • Cisco Employee,
  • Hall of Fame,
    2011
no
The following directories are supported by Unified CM for synchronization:
•Microsoft Active Directory (AD) 2000 and 2003
•Netscape Directory Server 4.x, iPlanet Directory Server 5.1, and Sun ONE Directory Server 5.2
Be aware even if you achieve the integration we won't support you
LDAP Directory Integration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/directry.html
java
if this helps, please rate
