USB MOH on 6.1
Feb 3rd, 2009
I have a customer that is using the Advitel MOH server to broadcast real time news updates, events and weather forecasts (etc) to callers placed on hold. I have connected the headset jack on the server to the mic input on the Cisco USB MOH card and the quality is very poor. The "esses" hiss and there is a lot of crackling. I guess this is due to input/output being balanced/unbalanced. Has anyone successfully attached another make of USB card that has a line in port rather than a mic in.
paul.higgsboyo@... Thu, 02/05/2009 - 07:29
If anyone has had this issue and been able to resolve it I would be grateful to know what sound card you used.
Paul
James Hawkins Tue, 03/10/2009 - 03:56
I have used a Griffin iMic to connect a CD player to a CallManager 4.2 server with acceptable quality. It has a line input.
http://www.griffintechnology.com/products/imic
In the Cisco docs I have seen only the iMic listed as supported for 3.x/4.x.
For Linux based versions of CallManager the only supported piece of hardware that I am aware of is Cisco's own MOH-USB-AUDIO= Music On Hold USB Audio Adapter which is the one that you are using.
paul.higgsboyo@... Mon, 09/21/2009 - 13:33
Hi Omni,
This is all sorted now but thanks for your comments. It transpired that the problem was with the recorded format of the original .wav files. The provider of the MoH files record their files in high quality format and then use EQing to compress / resample to a lower quality and that seems to be whats causing the problem. I created some of my own .wav files in the correct format for CUCM from the outset and they were fine.
Cheers,
Paul.
