02-03-2009 09:41 AM - edited 03-15-2019 03:57 PM
Folks
on the switch port, what is the vlan that needs to be associated to the port for the ATAs to work properly, the data vlan only or the voice vlan only
thanks
Solved! Go to Solution.
02-03-2009 09:59 AM
You could use either
Switchport access vlan(voice)
or
switchport access vlan(data)
switchport voice vlan(voice)
Let me know if this helps.
Mark
02-03-2009 09:59 AM
or
Mark
