You cannot schedule a backup while performing an immediate backup.
To specify a specific date and time when you want the database backup to begin, follow these steps:
a. Deselect the Immediate check box.
b. Use the scroll arrows to display the month, day, and year in the Start Date lists under Schedule, and then click each displayed value to confirm your selection.
Confirmed selections appear in blue.
c. Use the scroll arrows to display the hour and minutes in the Start Time lists under Schedule, and then click each displayed value to confirm your selection.
To specify that a backup should take place at regular intervals, follow these steps:
a. Enter a value in the Repeat After field, and select Days, Hours, or Minutes from the list. You must click your list selection after using the scroll arrows for the selection to take effect.
b. To limit the number of times the database backup occurs, enter a value in the Limit Occurrences field under Frequency.
To back up the database according to the settings you have made, click Finish.
