Unable to authenticate via Radius
I am unable to authenticate via Radius, the ACE server does not even see an attempt by the module. The following is my config in the Admin context:
radius-server retransmit 3
radius-server host 10.9.48.135 key 7 "*****" auth-port 1645 authentication ac
counting
radius-server host 10.3.8.213 key 7 "*****" auth-port 1645 authentication acc
ounting
aaa group server radius radius
aaa authentication login default group radius local
aaa accounting default group radius
Is there anything different that I need to configure on the ACE or the ACE server?
John..
Overall Rating: 5 (1 ratings)
ciscocsoc Wed, 02/04/2009 - 03:24
Hi John,
Under the "aaa group server radius radius" statement I'd expect to see server statements adding the previously defined radius servers. E.g see Command Reference manual under "(config) aaa group server" or Security Manual page 2-9++.
Cathy
Cathy,
You RULE, I found the Command Reference Manual and made the changes as you suggested. The problem I am now having is that when I log on via Radius I do not log on as the admin and cannot make any changes.
I read a previous thread from you that the change now has to happen in ACS, since I am not the ACS admin here can you please give me some detailed instruction on how the make the necessary changes to ACS so that I can relay it to my ACS admin?
Thank you very much,
John...
ciscocsoc Wed, 02/04/2009 - 08:33
John,
I don't use the ACS Radius either - but your admin can be pointed at the ACE documentation I referred to in the other thread. He/She should be able to work out what to do. It is generally easy to configure this using the ACS GUI. Failing that they could ask a question on the appropriate forum.
Kind Regards
Cathy
