Transferring file to MeetingPlace Express remotely
gsidhu
Level 3
Level 3
I'm in the process of carrying out MeetingPlace Express upgrade remotely via SSH.
One of the steps is to transfer the upgrade file onto MeetingPlace Express.
The file is in the a local windows pc in the c:\mpxupgrades directory.
I get the following error when I try to transfer the file:
[root@mpxSystem upgrades]# scp c:\mpxupgrade\CUMPE_Upgrade-2.0.2.126.bin /upgrades
ssh: c: Temporary failure in name resolution
Please could somebody tell me what the correct syntax is:
IP address of pc where upgrade patch is 172.30.4.240
IP address of mpx is 172.30.200.11
owillins
Level 6
Level 6
Make sure you have Change to the root user by entering su - and enter the root password.
In the Connect to Remote Host dialog box, enter the following values:
Host Name: IP address of your Cisco Unified MeetingPlace Express system
User Name: mpxadmin
Port Number: 22
Authentication Method: leave as
The installation guide assumes you have the SCP client/daemon running on your computer.
I managed to get round the problem:
1) Log into MPX via WinSCP software - you can only login as mpxadmin; su - does not work:
You can download WinSCP here:
http://winscp.net/eng/download.php
2) SSH to MPX, switch to root then move file into a partition that has lots of space.
3) use chmod 777 on the file to change permissions.
