Unity Auto Attendant - Routing when a subscriber is not forund
Feb 3rd, 2009
I have an auto attendant set up for a site that allows caller input.
If the extension does not exist unity responds with "I did not recognize that as a valid entry" and gets routed to the opening
greeting. I want to route this to the sites operator but can't figure out how to
accomplish that. I played around with the routing rules a bit but I was still unable to get the call to route correctly.
<br />
<br />
Overall Rating: 5 (2 ratings)
Jaime Valencia Tue, 02/03/2009 - 13:51
  • Cisco Employee,
  • Hall of Fame,
    2011
you need to configure a caller input to a call system transfer, then from there dial any DN you want
java
if this helps, please rate
roboliveira Tue, 02/03/2009 - 13:54
No what I want to happen is if the extension is invalid I want the call to automatically route to an operator.
roboliveira Tue, 02/03/2009 - 14:09
Awesome! I didn't even know this setting existed. 5 to you!
